I’ve been using Cryptomator for a while now without issues. This morning, I went to access my 3 existing vaults and all of them say “Cryptomator could not find a vault at this path.” I tried to re-add the vaults, but it says an unexpected error occurred and prompts me to report the error text below. I tried creating a new vault to get a valid master key, copied it into the root directory, and tried to re-add the vault again, but get the same error message again. Can anyone help me with this?
java.nio.file.NoSuchFileException: /Users/joycejshin/Library/Mobile Documents/iCloud~com~setolabs~Cryptomator/Documents/Documents: Not a vault directory
at org.cryptomator.common.vaults.VaultListManager.add(VaultListManager.java:57)
at org.cryptomator.ui.addvaultwizard.ChooseExistingVaultController.chooseFileAndNext(ChooseExistingVaultController.java:81)
at jdk.internal.reflect.GeneratedMethodAccessor32.invoke(Unknown Source)
at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1859)
at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1729)
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:234)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49)
at javafx.event.Event.fireEvent(Event.java:198)
at javafx.scene.Node.fireEvent(Node.java:8889)
at javafx.scene.control.Button.fire(Button.java:203)
at com.sun.javafx.scene.control.behavior.ButtonBehavior.mouseReleased(ButtonBehavior.java:208)
at com.sun.javafx.scene.control.inputmap.InputMap.handle(InputMap.java:274)
at com.sun.javafx.event.CompositeEventHandler$NormalEventHandlerRecord.handleBubblingEvent(CompositeEventHandler.java:247)
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:80)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
at javafx.scene.Scene$MouseHandler.process(Scene.java:3856)
at javafx.scene.Scene.processMouseEvent(Scene.java:1851)
at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2584)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:409)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:299)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$2(GlassViewEventHandler.java:447)
at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:412)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:446)
at com.sun.glass.ui.View.handleMouseEvent(View.java:556)
at com.sun.glass.ui.View.notifyMouse(View.java:942)
at com.sun.glass.ui.mac.MacView.notifyMouse(MacView.java:127)
