I wanted to delete a vault so I removed it from cryptomator (while it was opened) and now it is permanently showing up as a drive and not going anywhere. I re-added the vault inside cryptomator and it shows it as locked now. I entered the password but it is stuck in the “unlocking…” screen.
Any tips on how to fix this? I want to reinstall my windows and I hope this two-drive system doesn’t persist or my hard disk doesn’t get corrupted, thanks!
picture: https://ibb.co/TTf1JSk
a restart of your computer should fix this issue.
Removing a vault while it is open is a known bug we recently fixed and it will be included in the next release.
