Hello.
I tried to open my vault, it crashed on both 1.5.11 and 1.5.15.
It worked before.
Intel MacBook, Big Sur 11.3.1
Getting this error:
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:54)
Caused by: org.cryptomator.frontend.fuse.mount.FuseMountException: ru.serce.jnrfuse.FuseException: Unable to mount FS
at org.cryptomator.frontend.fuse.mount.AbstractMounter.mount(AbstractMounter.java:46)
at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:15)
... 12 more
at org.cryptomator.frontend.fuse.mount.AbstractMounter.lambda$mount$0(AbstractMounter.java:26)
... 1 more
... 2 more
