Sorry, I missed the long debug-log:
15:00:59.658 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.3.1 on Windows 10 10.0 (amd64)
15:01:01.131 [JavaFX Application Thread] INFO o.c.launcher.MainApplication - JavaFX application started.
15:01:01.213 [JavaFX Application Thread] INFO o.c.common.settings.SettingsProvider - Settings loaded from C:\Users\WEIDINGE\AppData\Roaming\Cryptomator\settings.json
15:01:01.214 [JavaFX Application Thread] DEBUG org.cryptomator.logging.DebugMode - Debug mode initialized
15:01:01.218 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Loaded localization default file: /localization/en.txt
15:01:01.219 [JavaFX Application Thread] DEBUG org.cryptomator.ui.l10n.Localization - Detected language “de” and region “DE”
15:01:01.220 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de_DE.txt
15:01:01.221 [JavaFX Application Thread] TRACE org.cryptomator.ui.l10n.Localization - Attempting to load localization from: /localization/de.txt
15:01:01.628 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded WinFunctions.dll
15:01:01.683 [JavaFX Application Thread] INFO org.eclipse.jetty.util.log - Logging initialized @2379ms to org.eclipse.jetty.util.log.Slf4jLog
15:01:01.740 [JavaFX Application Thread] INFO o.c.frontend.webdav.WebDavServer - Binding server socket to 127.0.0.1:56735
15:01:01.758 [JavaFX Application Thread] INFO o.e.jetty.server.AbstractConnector - Started ServerConnector@2ef3df4c{HTTP/1.1,[http/1.1]}{127.0.0.1:56735}
15:01:02.037 [pool-4-thread-1] DEBUG o.c.ui.controllers.WelcomeController - Checking for updates…
15:01:07.334 [JavaFX Application Thread] ERROR o.c.ui.util.AsyncTaskService - Uncaught exception
org.apache.http.conn.ConnectTimeoutException: Connect to api.cryptomator.org:443 [api.cryptomator.org/185.170.112.120] failed: connect timed out
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:151)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:359)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:381)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:237)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:185)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:111)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at org.cryptomator.ui.controllers.WelcomeController.lambda$checkForUpdates$0(WelcomeController.java:130)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Caused by: java.net.SocketTimeoutException: connect timed out
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:339)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
… 18 common frames omitted
15:01:13.034 [JavaFX Application Thread] INFO o.c.k.WindowsProtectedKeychainAccess - Creating new keychain at path C:\Users\WEIDINGE\AppData\Roaming\Cryptomator\keychain.json
15:01:20.607 [pool-4-thread-1] INFO org.eclipse.jetty.server.Server - jetty-9.4.6.v20170531
15:01:20.637 [pool-4-thread-1] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@77fdabfa{/,null,AVAILABLE}
15:01:20.638 [pool-4-thread-1] INFO org.eclipse.jetty.server.Server - Started @21335ms
15:01:20.638 [pool-4-thread-1] INFO o.c.frontend.webdav.WebDavServer - WebDavServer started.
15:01:20.677 [pool-4-thread-1] INFO org.eclipse.jetty.server.session - DefaultSessionIdManager workerName=node0
15:01:20.677 [pool-4-thread-1] INFO org.eclipse.jetty.server.session - No SessionScavenger set, using defaults
15:01:20.678 [pool-4-thread-1] INFO org.eclipse.jetty.server.session - Scavenging every 660000ms
15:01:20.685 [pool-4-thread-1] INFO o.a.j.w.server.AbstractWebdavServlet - authenticate-header = Basic realm=“Jackrabbit Webdav Server”
15:01:20.686 [pool-4-thread-1] INFO o.a.j.w.server.AbstractWebdavServlet - csrf-protection = null
15:01:20.686 [pool-4-thread-1] INFO o.a.j.w.server.AbstractWebdavServlet - createAbsoluteURI = true
15:01:20.686 [pool-4-thread-1] INFO o.e.j.server.handler.ContextHandler - Started o.e.j.s.ServletContextHandler@7982aba0{/SdoGin8RRImT/Privat,null,AVAILABLE}
15:01:20.686 [pool-4-thread-1] INFO o.c.f.w.s.WebDavServletController - WebDavServlet started: /SdoGin8RRImT/Privat
15:01:20.740 [pool-4-thread-1] INFO o.c.f.w.s.WebDavServletController - Mounting http://127.0.0.1:56735/SdoGin8RRImT/Privat using org.cryptomator.frontend.webdav.mount.WindowsMounter
15:01:20.811 [pool-4-thread-1] DEBUG o.c.f.webdav.mount.WindowsMounter - Original Registry value for ProxyOverride is: ;cryptomator-vault:56735;cryptomator-vault
15:01:20.812 [pool-4-thread-1] DEBUG o.c.f.webdav.mount.WindowsMounter - Setting Registry value for ProxyOverride to: ;cryptomator-vault:56735;cryptomator-vault
15:01:21.029 [pool-5-thread-5] DEBUG org.eclipse.jetty.server.HttpChannel - new HttpChannelOverHttp@428e9cc6{r=0,c=false,a=IDLE,uri=null} → SocketChannelEndPoint@5b124fb1{/127.0.0.1:52027<->/127.0.0.1:56735,OPEN,fill=-,flush=-,to=46/30000}{io=0/0,kio=0,kro=0}->,null,HttpChannelState@36f956c4{s=IDLE a=NOT_ASYNC i=true r=IDLE w=false}
15:01:21.044 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //cryptomator-vault:56735/SdoGin8RRImT/Privat on HttpChannelOverHttp@428e9cc6{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat}
PROPFIND //cryptomator-vault:56735/SdoGin8RRImT/Privat HTTP/1.1
Connection: keep-alive
User-Agent: Microsoft-WebDAV-MiniRedir/10.0.14393
Depth: 0
translate: f
Content-Length: 0
Host: cryptomator-vault:56735
15:01:21.044 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} onContentComplete
15:01:21.045 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} onRequestComplete
15:01:21.045 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} handle //cryptomator-vault:56735/SdoGin8RRImT/Privat
15:01:21.047 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=1,c=false,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} action DISPATCH
15:01:21.049 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@731f34d8[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@6950d674{null}
15:01:21.050 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /SdoGin8RRImT/Privat on HttpChannelOverHttp@428e9cc6{r=1,c=true,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat}
302 null HTTP/1.1
Date: Mon, 04 Sep 2017 13:01:21 GMT
Location: http://cryptomator-vault:56735/SdoGin8RRImT/Privat/
15:01:21.053 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=1,c=true,a=COMPLETING,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} action COMPLETE
15:01:21.053 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /SdoGin8RRImT/Privat written=0
15:01:21.055 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=1,c=false,a=IDLE,uri=null} handle exit, result COMPLETE
15:01:21.055 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //cryptomator-vault:56735/SdoGin8RRImT/Privat/ on HttpChannelOverHttp@428e9cc6{r=2,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/}
PROPFIND //cryptomator-vault:56735/SdoGin8RRImT/Privat/ HTTP/1.1
Depth: 0
translate: f
Content-Length: 0
15:01:21.055 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=2,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} onContentComplete
15:01:21.055 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=2,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} onRequestComplete
15:01:21.056 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=2,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} handle //cryptomator-vault:56735/SdoGin8RRImT/Privat/
15:01:21.056 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=2,c=false,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} action DISPATCH
15:01:21.060 [pool-5-thread-1] TRACE o.c.f.webdav.servlet.LoggingFilter - REQUEST 0:
PROPFIND /SdoGin8RRImT/Privat/ HTTP/1.1
Content-Length: 0
Depth: 0
translate: f
15:01:21.160 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@2aa9c65[p=0,l=481,c=481,r=481]={<<<<?xml version="1…/D:multistatus>>>>} complete=true committing=true callback=Blocker@6950d674{null}
15:01:21.160 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /SdoGin8RRImT/Privat/ on HttpChannelOverHttp@428e9cc6{r=2,c=true,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/}
207 null HTTP/1.1
Content-Type: text/xml;charset=utf-8
Content-Length: 481
15:01:21.161 [pool-5-thread-1] TRACE o.c.f.webdav.servlet.LoggingFilter - RESPONSE 0:
207
Content-Length: 481
15:01:21.162 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=2,c=true,a=COMPLETING,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} action COMPLETE
15:01:21.162 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /SdoGin8RRImT/Privat/ written=481
15:01:21.162 [pool-5-thread-1] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@428e9cc6{r=2,c=false,a=IDLE,uri=null} handle exit, result COMPLETE
15:01:21.169 [pool-5-thread-8] DEBUG org.eclipse.jetty.server.HttpChannel - new HttpChannelOverHttp@36897899{r=0,c=false,a=IDLE,uri=null} → SocketChannelEndPoint@384e91e0{/127.0.0.1:52028<->/127.0.0.1:56735,OPEN,fill=-,flush=-,to=0/30000}{io=0/0,kio=0,kro=0}->,null,HttpChannelState@32b6fa90{s=IDLE a=NOT_ASYNC i=true r=IDLE w=false}
15:01:21.171 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //cryptomator-vault:56735/SdoGin8RRImT/Privat on HttpChannelOverHttp@36897899{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat}
Depth: 0
translate: f
Content-Length: 0
15:01:21.172 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} onContentComplete
15:01:21.172 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} onRequestComplete
15:01:21.172 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} handle //cryptomator-vault:56735/SdoGin8RRImT/Privat
15:01:21.172 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=1,c=false,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} action DISPATCH
15:01:21.173 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@731f34d8[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@1b06240e{null}
15:01:21.173 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /SdoGin8RRImT/Privat on HttpChannelOverHttp@36897899{r=1,c=true,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat}
302 null HTTP/1.1
15:01:21.174 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=1,c=true,a=COMPLETING,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat} action COMPLETE
15:01:21.174 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /SdoGin8RRImT/Privat written=0
15:01:21.174 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=1,c=false,a=IDLE,uri=null} handle exit, result COMPLETE
15:01:21.175 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //cryptomator-vault:56735/SdoGin8RRImT/Privat/ on HttpChannelOverHttp@36897899{r=2,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/}
Depth: 0
translate: f
Content-Length: 0
15:01:21.175 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=2,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} onContentComplete
15:01:21.175 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=2,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} onRequestComplete
15:01:21.176 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=2,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} handle //cryptomator-vault:56735/SdoGin8RRImT/Privat/
15:01:21.176 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=2,c=false,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} action DISPATCH
15:01:21.176 [pool-5-thread-2] TRACE o.c.f.webdav.servlet.LoggingFilter - REQUEST 1:
Content-Length: 0
Depth: 0
translate: f
15:01:21.179 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@6392699c[p=0,l=481,c=481,r=481]={<<<<?xml version="1…/D:multistatus>>>>} complete=true committing=true callback=Blocker@1b06240e{null}
15:01:21.180 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /SdoGin8RRImT/Privat/ on HttpChannelOverHttp@36897899{r=2,c=true,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/}
207 null HTTP/1.1
Content-Length: 481
15:01:21.180 [pool-5-thread-2] TRACE o.c.f.webdav.servlet.LoggingFilter - RESPONSE 1:
207
Content-Length: 481
15:01:21.181 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=2,c=true,a=COMPLETING,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/} action COMPLETE
15:01:21.181 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /SdoGin8RRImT/Privat/ written=481
15:01:21.181 [pool-5-thread-2] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@36897899{r=2,c=false,a=IDLE,uri=null} handle exit, result COMPLETE
15:01:21.188 [pool-4-thread-1] DEBUG o.c.f.webdav.mount.WindowsMounter - Mounted \cryptomator-vault@56735\DavWWWRoot\SdoGin8RRImT\Privat on drive N:
15:01:21.190 [JavaFX Application Thread] TRACE o.c.u.controllers.UnlockedController - Mount succeeded.
15:01:21.233 [pool-5-thread-7] DEBUG org.eclipse.jetty.server.HttpChannel - new HttpChannelOverHttp@31be1410{r=0,c=false,a=IDLE,uri=null} → SocketChannelEndPoint@74bc84e3{/127.0.0.1:52029<->/127.0.0.1:56735,OPEN,fill=-,flush=-,to=0/30000}{io=0/0,kio=0,kro=0}->,null,HttpChannelState@68df4dc3{s=IDLE a=NOT_ASYNC i=true r=IDLE w=false}
15:01:21.236 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini on HttpChannelOverHttp@31be1410{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini}
PROPFIND //cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini HTTP/1.1
Depth: 0
translate: f
Content-Length: 0
15:01:21.236 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@31be1410{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini} onContentComplete
15:01:21.237 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@31be1410{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini} onRequestComplete
15:01:21.237 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@31be1410{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini} handle //cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini
15:01:21.237 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@31be1410{r=1,c=false,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini} action DISPATCH
15:01:21.238 [pool-5-thread-9] TRACE o.c.f.webdav.servlet.LoggingFilter - REQUEST 2:
PROPFIND /SdoGin8RRImT/Privat/Desktop.ini HTTP/1.1
Content-Length: 0
Depth: 0
translate: f
15:01:21.243 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@731f34d8[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@6dd6c3c7{null}
15:01:21.244 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /SdoGin8RRImT/Privat/Desktop.ini on HttpChannelOverHttp@31be1410{r=1,c=true,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini}
404 Not Found HTTP/1.1
15:01:21.244 [pool-5-thread-9] TRACE o.c.f.webdav.servlet.LoggingFilter - RESPONSE 2:
404
15:01:21.245 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@31be1410{r=1,c=true,a=COMPLETING,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/Desktop.ini} action COMPLETE
15:01:21.245 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /SdoGin8RRImT/Privat/Desktop.ini written=0
15:01:21.245 [pool-5-thread-9] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@31be1410{r=1,c=false,a=IDLE,uri=null} handle exit, result COMPLETE
15:01:21.255 [pool-5-thread-10] DEBUG org.eclipse.jetty.server.HttpChannel - new HttpChannelOverHttp@10feca8a{r=0,c=false,a=IDLE,uri=null} → SocketChannelEndPoint@55fc4e51{/127.0.0.1:52030<->/127.0.0.1:56735,OPEN,fill=-,flush=-,to=1/30000}{io=0/0,kio=0,kro=0}->,null,HttpChannelState@6e2dc899{s=IDLE a=NOT_ASYNC i=true r=IDLE w=false}
15:01:21.270 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - REQUEST for //cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf on HttpChannelOverHttp@10feca8a{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf}
PROPFIND //cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf HTTP/1.1
Depth: 0
translate: f
Content-Length: 0
15:01:21.271 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@10feca8a{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf} onContentComplete
15:01:21.271 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@10feca8a{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf} onRequestComplete
15:01:21.272 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@10feca8a{r=1,c=false,a=IDLE,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf} handle //cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf
15:01:21.272 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@10feca8a{r=1,c=false,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf} action DISPATCH
15:01:21.272 [pool-5-thread-11] TRACE o.c.f.webdav.servlet.LoggingFilter - REQUEST 3:
PROPFIND /SdoGin8RRImT/Privat/AutoRun.inf HTTP/1.1
Content-Length: 0
Depth: 0
translate: f
15:01:21.277 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - sendResponse info=null content=HeapByteBuffer@731f34d8[p=0,l=0,c=0,r=0]={<<<>>>} complete=true committing=true callback=Blocker@56719b8f{null}
15:01:21.277 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - COMMIT for /SdoGin8RRImT/Privat/AutoRun.inf on HttpChannelOverHttp@10feca8a{r=1,c=true,a=DISPATCHED,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf}
15:01:21.278 [pool-5-thread-11] TRACE o.c.f.webdav.servlet.LoggingFilter - RESPONSE 3:
404
15:01:21.278 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@10feca8a{r=1,c=true,a=COMPLETING,uri=//cryptomator-vault:56735/SdoGin8RRImT/Privat/AutoRun.inf} action COMPLETE
15:01:21.278 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - COMPLETE for /SdoGin8RRImT/Privat/AutoRun.inf written=0
15:01:21.279 [pool-5-thread-11] DEBUG org.eclipse.jetty.server.HttpChannel - HttpChannelOverHttp@10feca8a{r=1,c=false,a=IDLE,uri=null} handle exit, result COMPLETE
15:01:21.315 [JavaFX Application Thread] TRACE o.c.u.controllers.UnlockedController - Reveal succeeded.
