Can crypomator be connected with the E-Post cloud?
In my app I can find the connection to Dropbox and Onedrive.
Is it planned to extend the list of cloud services?
Is there a way to connect other cloud services in a general way.
Cheers
Peter
Cheers
Peter
You can connect to any storage provider who offers a connection via WebDAV (mobile apps) or a sync client (desktop)
As far as I know, E-Post does not offer WebDAV, but brings its own sync client. So unfortunately you cannot use E-Post with the android or iPhone app. But you can use it with the cryptomator desktop app
Hi Miachel,
thanks a lot for the quick answer. I’ll try.
Cheers
