Cross-Platforms encryption with Cryptomator
How can I use Cryptomator cross-platform Linux-Windows ? I have already encrypted folders with Cryptomator on Windows 10. Now I want to decrypt them with Cryptomator on Linux Mint 22.3. I don’t see any option on Cryptomator-Linux to open those folders.
Update:
Thanks, but I have resolved this.
Your Linux computer needs access to the vault that you created on Windows 10.This is under the presumption that the vault you created is on your Windows 10 computer and not on the server?
Presuming the files are on the Windows 10 computer, you would need to do some sort of file sharing between Windows and Linux, such as SMB (Microsoft file sharing). Then Linux can mount the vault on the Windows 10 computer.
Alternatively you can use Open SSH server on both computers to access the vault from Linux that’s on the Windows computer. The basic point is you need to have some sort of file sharing so the Cryptomator running on the Linux machine can access the vault on the Windows 10 computer.
If you share some more specifics as to where the vault is, I can provide further guidance.
