Hi
12:54:35.111 [Background Thread 2] INFO o.c.f.w.s.WebDavServletController - Mounting http://localhost:42427/DLOyUaiMRWG3/backup using org.cryptomator.frontend.webdav.mount.MacAppleScriptMounter
12:54:38.577 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
org.cryptomator.ui.model.Volume$VolumeException: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: 0:57: execution error: An error of type -5014 has occurred. (-5014)
at org.cryptomator.ui.model.WebDavVolume.mount(WebDavVolume.java:62)
at org.cryptomator.ui.model.WebDavVolume.mount(WebDavVolume.java:46)
at org.cryptomator.ui.model.Vault.unlock(Vault.java:115)
at org.cryptomator.ui.controllers.UnlockController.lambda$didClickUnlockButton$0(UnlockController.java:494)
Caused by: org.cryptomator.frontend.webdav.mount.Mounter$CommandFailedException: Command failed with exit code 1. Expected 0. Stderr: 0:57: execution error: An error of type -5014 has occurred. (-5014)
at org.cryptomator.frontend.webdav.mount.MacAppleScriptMounter.mount(MacAppleScriptMounter.java:50)
at org.cryptomator.ui.model.WebDavVolume.mount(WebDavVolume.java:59)
... 12 common frames omitted
I use
no_proxy=localhost,127.0.0.1
and start the app from CLI, but still the connection error.
