I synced a copy of my of my Cryptomator documents vault to my phone and try to access it on my phone using the Cryptomator Android app.
However, when I try to open the vault in the app, by navigating to the folder (Saved on SD card) and selecting masterkey file it appears in the cryptomator app with a blank name and reads the error message when I press on it: ’Vault not found The vault has been renamed, moved or deleted. Remove this vault from the list and add it again to proceed. Remove now?
I am using a Samsung S8 and 256GB SD card. I copied the Vault over usb on windows file explorer and intend to syncronize over Mega.nz cloud storage with PCusing the MegaSync Pro app.
Am I missing something? I just bought the Cryptomator app. Is it possible to access a local copy of a PC encrypted vault on Android app?
Sorry I didn’t make myself clearer. I meant the part where you created a custom location.
If you are in the vault list, then click on the “+” sign --> “Add existing vault” --> “Local storage” --> “+” --> (now you have to select at least a parent of the vault folder) e.g. SD CARD directly
