I installed Cryptomator latest version on a Windows Server 2012 R2, VPS. The installation seemed to finish correctly.
However when I try to open a vault, I get the error message “Connecting drive failed”. The vault is unlocked but just does not mount.
Is cryptomator supported on Windows Server 2012 R2?
Is there anything I need to install/check/role for this.
cheers and thanks
