Hello everyone,
with the 1.7.1 update, the drive letter cannot be customized.
As soon as I try to mount the vault, I get the following error message.
Error Code GH1B:GH1B:NJFJ
org.cryptomator.integrations.mount.MountFailedException: java.io.IOException: Command failed with exit code 2. Expected 0.
at org.cryptomator.frontend.webdav@2.0.1/org.cryptomator.frontend.webdav.mount.WindowsMounter$MountBuilderImpl.mount(WindowsMounter.java:130)
at org.cryptomator.frontend.webdav@2.0.1/org.cryptomator.frontend.webdav.mount.AbstractMountBuilder.mount(AbstractMountBuilder.java:88)
at org.cryptomator.desktop@1.7.1/org.cryptomator.common.mount.Mounter.mount(Mounter.java:134)
at org.cryptomator.desktop@1.7.1/org.cryptomator.common.vaults.Vault.unlock(Vault.java:150)
at org.cryptomator.desktop@1.7.1/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
at org.cryptomator.desktop@1.7.1/org.cryptomator.ui.unlock.UnlockWorkflow.attemptUnlock(UnlockWorkflow.java:70)
at org.cryptomator.desktop@1.7.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:60)
at org.cryptomator.desktop@1.7.1/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:31)
Caused by: java.io.IOException: Command failed with exit code 2. Expected 0.
at org.cryptomator.frontend.webdav@2.0.1/org.cryptomator.frontend.webdav.mount.ProcessUtil.assertExitValue(ProcessUtil.java:25)
at org.cryptomator.frontend.webdav@2.0.1/org.cryptomator.frontend.webdav.mount.WindowsMounter$MountBuilderImpl.mount(WindowsMounter.java:117)
... 13 more
Caused by: java.io.IOException: Stderr output: Systemfehler 67 aufgetreten.
Der Netzwerkname wurde nicht gefunden.
at org.cryptomator.frontend.webdav@2.0.1/org.cryptomator.frontend.webdav.mount.ProcessUtil.assertExitValue(ProcessUtil.java:23)
... 14 more
It wokrs without problems with the automatic assignment of the drive letter.
Greeting
LDSer
