When I try to unlock it just fails regardless of what password I put in.
LOG:
16:38:59.507 [main] INFO org.cryptomator.launcher.Cryptomator - Starting Cryptomator 1.4.15 on Mac OS X 10.15 (x86_64)
16:38:59.624 [main] INFO o.c.launcher.IpcProtocolImpl - Received launch args:
16:38:59.927 [JavaFX Application Thread] INFO org.cryptomator.launcher.Cryptomator - JavaFX application started.
16:39:00.010 [JavaFX Application Thread] INFO org.cryptomator.jni.JniModule - loaded libMacFunctions.dylib
16:39:01.709 [JavaFX Application Thread] INFO o.c.ui.controllers.WelcomeController - Current version: 1.4.15, lastest version: 1.4.15
16:39:17.395 [JavaFX Application Thread] ERROR o.c.ui.controllers.UnlockController - Unlock failed for technical reasons.
java.io.IOException: Error during file system creation.
at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:44)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:257)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:88)
at java.base/java.nio.file.FileSystems.newFileSystem(FileSystems.java:344)
at java.base/java.nio.file.FileSystems.newFileSystem(FileSystems.java:293)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.newFileSystem(CryptoFileSystemProvider.java:128)
at org.cryptomator.ui.model.Vault.unlockCryptoFileSystem(Vault.java:92)
at org.cryptomator.ui.model.Vault.lambda$getCryptoFileSystem$0(Vault.java:79)
at java.base/java.util.concurrent.atomic.AtomicReference.updateAndGet(AtomicReference.java:209)
at org.cryptomator.ui.model.Vault.getCryptoFileSystem(Vault.java:79)
at org.cryptomator.ui.model.Vault.unlock(Vault.java:113)
at org.cryptomator.ui.controllers.UnlockController.lambda$didClickUnlockButton$0(UnlockController.java:494)
Caused by: java.io.UncheckedIOException: java.io.IOException: Mount point not found in fstab
at org.cryptomator.cryptofs.ReadonlyFlag.targetFileStoreIsReadonly(ReadonlyFlag.java:38)
at org.cryptomator.cryptofs.ReadonlyFlag.<init>(ReadonlyFlag.java:25)
at org.cryptomator.cryptofs.ReadonlyFlag_Factory.get(ReadonlyFlag_Factory.java:25)
at org.cryptomator.cryptofs.ReadonlyFlag_Factory.get(ReadonlyFlag_Factory.java:8)
at org.cryptomator.cryptofs.CryptoFileSystemModule_ProvideCryptorFactory.get(CryptoFileSystemModule_ProvideCryptorFactory.java:46)
at org.cryptomator.cryptofs.CryptoFileSystemImpl_Factory.get(CryptoFileSystemImpl_Factory.java:111)
at org.cryptomator.cryptofs.CryptoFileSystemImpl_Factory.get(CryptoFileSystemImpl_Factory.java:13)
at org.cryptomator.cryptofs.DaggerCryptoFileSystemProviderComponent$CryptoFileSystemComponentImpl.cryptoFileSystem(DaggerCryptoFileSystemProviderComponent.java:362)
at org.cryptomator.cryptofs.CryptoFileSystems.lambda$create$0(CryptoFileSystems.java:38)
at java.base/java.util.concurrent.ConcurrentHashMap.compute(ConcurrentHashMap.java:1908)
at org.cryptomator.cryptofs.CryptoFileSystems.create(CryptoFileSystems.java:30)
... 22 common frames omitted
Caused by: java.io.IOException: Mount point not found in fstab
at java.base/sun.nio.fs.BsdFileStore.findMountEntry(BsdFileStore.java:86)
at java.base/sun.nio.fs.UnixFileStore.<init>(UnixFileStore.java:67)
at java.base/sun.nio.fs.BsdFileStore.<init>(BsdFileStore.java:40)
at java.base/sun.nio.fs.BsdFileSystemProvider.getFileStore(BsdFileSystemProvider.java:46)
at java.base/sun.nio.fs.BsdFileSystemProvider.getFileStore(BsdFileSystemProvider.java:34)
at java.base/sun.nio.fs.UnixFileSystemProvider.getFileStore(UnixFileSystemProvider.java:369)
at java.base/java.nio.file.Files.getFileStore(Files.java:1487)
at org.cryptomator.cryptofs.ReadonlyFlag.targetFileStoreIsReadonly(ReadonlyFlag.java:36)
... 36 common frames omitted
