Trying to open the vault with FUSE results in this error being displayed:
at org.cryptomator.common.vaults.Vault.unlock(Vault.java:142)
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:48)
at org.cryptomator.frontend.fuse.mount.Mounter.mount(Mounter.java:8)
at org.cryptomator.common.vaults.FuseVolume.mount(FuseVolume.java:50)
... 12 more
at org.cryptomator.frontend.fuse.mount.MacMounter.mount(MacMounter.java:46)
... 14 more
... 15 more
This happens with macOS 11.2.2, Cryptomator 1.5.13 and macFUSE 4.0.5. I can open it with WebDAV.
