The manual says “As long as the vaults are unlocked, the Cryptomator window can be closed without quitting the application. Cryptomator will be minimized to the tray icon. By right clicking the tray icon, you can open or quit Cryptomator.”
But I can’t. If I close the window, the program exits, and I think I can loose data.
Hi. Did you look in the Task Manager if the cryptomator process is still running?
Do you have error messages in you logfile?
Do you use 3rd party apps to manage your system tray (like TrayIt or something like that)?
Maybe there is just an issue with displaying the cryptomator symbol in the tray.
Actually there is no function or configuration in cryptomator for this, so the cryptomator window should always close without quitting.
There is no cryptomator task running, nothing in log, nothing at all. Program simply closes, and vaults lock /if you run cryptomator again you have to unlock them). No message saying “are you sure to close?”, nothing. Thanks.
On Linux, the app does exit without asking when closing the window. I have tried under Fedora 27 with the TopIcons Plus Gnome extension that allows for tray icons in the top bar, since Gnome 3.26 got rid of tray icons.
