Cannot unlock vault
i Don’t know how to explain this because my english is bad , i have a Big issue i download cryptomator on my window 11 to protected my 102 GB Dta folder i moved that folder to C/users/public with the folder name Window 11 update then i protect the folder using cryptomator sofware with Password ( No Recovery keys etc ) Just Password ) it sucessfully protected then i turn off my laptop when i came back That Protected D drive which appear during protection disappeared and i have now only these folders left i know my password but i can’t able to unlock that can anyone look into it and tell me the solution Please
Hi
There must be at least one file named Masterkey.cryptomator and one file named vault.cryptomator besides your folder “d”
There’s files are missing.
If you can’t restore them and don’t have a recovery key, there’s no way to unlock your vault.
This is how a vault typically looks like. Please note that these files/folders are stored in a folder that is named like you vault. Do not place it in the root of your drive.
Please note also, that folder “c” can be empty or even not exist. This is not a problem.
The 123abcxxx.bkup files are just backups created by cryptomator after successful logins. Also not a problem if they do not exist.
I understand that part but the problem is there is no backup files like you mention it’s just D Folder there
You you don’t have a backup elsewhere, then I am afraid your vault is lost.
but that’s what i need to understand , i never deleted that i never saw that where it’s gone?
