Cannot log in:, please help! Error Code GH1B:GH1B:JCKJ
org.cryptomator.integrations.mount.MountFailedException: java.io.IOException: Command failed with exit code 2. Expected 0.
	at org.cryptomator.frontend.webdav@2.0.6/org.cryptomator.frontend.webdav.mount.WindowsMounter$MountBuilderImpl.mount(WindowsMounter.java:130)
	at org.cryptomator.frontend.webdav@2.0.6/org.cryptomator.frontend.webdav.mount.AbstractMountBuilder.mount(AbstractMountBuilder.java:88)
	at org.cryptomator.desktop@1.14.0/org.cryptomator.common.mount.Mounter.mount(Mounter.java:172)
	at org.cryptomator.desktop@1.14.0/org.cryptomator.common.vaults.Vault.unlock(Vault.java:163)
	at org.cryptomator.desktop@1.14.0/org.cryptomator.ui.keyloading.KeyLoadingStrategy.use(KeyLoadingStrategy.java:79)
	at org.cryptomator.desktop@1.14.0/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:76)
	at org.cryptomator.desktop@1.14.0/org.cryptomator.ui.unlock.UnlockWorkflow.call(UnlockWorkflow.java:34)
	at javafx.graphics@22.0.2/javafx.concurrent.Task$TaskCallable.call(Unknown Source)
Caused by: java.io.IOException: Command failed with exit code 2. Expected 0.
	at org.cryptomator.frontend.webdav@2.0.6/org.cryptomator.frontend.webdav.mount.ProcessUtil.assertExitValue(ProcessUtil.java:25)
	at org.cryptomator.frontend.webdav@2.0.6/org.cryptomator.frontend.webdav.mount.WindowsMounter$MountBuilderImpl.mount(WindowsMounter.java:117)
	... 13 more
Caused by: java.io.IOException: Stderr output: System error 67 has occurred.
The network name cannot be found.
	at org.cryptomator.frontend.webdav@2.0.6/org.cryptomator.frontend.webdav.mount.ProcessUtil.assertExitValue(ProcessUtil.java:23)
	... 14 more
