Hi, I’ve installed the version 1.5.13 on my MAC M1, Big Sur OSX. It’s possible to deposit or copy files in the vault. But but save just a file(s) from any application causes systematically the MAC to fail and his reboot. How can I solve this problem? Thank you for your help.
this is a known bug on Apple M1 devices:
Unfortunately, the problem lies within Finder and its implementation of the WebDAV protocol, which means Apple needs to fix this.
The only current workaround is to install MacFuse und select FUSE instead of WebDAV in the general preferences.
