Per the error message: “This should not have happened. Please report the error text below…”
The error message does not specify where or to whom I should report the error, so I am posting the error text here. I briefly looked through the Cryptomator documentation to see if there were instructions on where to report the error. But I did not find anything, and I am at work, so I cannot spend more time on this right now. I did see a GitHub post mentioning a new vault format, so maybe that is the reason for this error. But if I am posting this in the wrong place, my apologies. Error text below:
... 11 more
... 13 more
What steps lead to this error? I just tried to open my vault as I usually do. Thank you for your time and attention to this error report.
