Running 1.4.x before on Win10. Deinstalled dokany, full new install of 1.5.4.
After installation, trying to migrate, but I get this error:
org.cryptomator.cryptofs.migration.v7.InvalidOldFilenameException: Can't base32-decode '6WONUQ==' in file C:\Users\Heiko\one-drive-full-domainname\subfolder\d\FY\327T67G2FLRNH4XWMZF4BSAPBAZEQO\06WONUQ==
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.getDecodedCiphertext(FilePathMigration.java:223)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.getNewInflatedName(FilePathMigration.java:209)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.migrate(FilePathMigration.java:122)
at org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory(MigratingVisitor.java:55)
at org.cryptomator.cryptofs.migration.v7.MigratingVisitor.postVisitDirectory(MigratingVisitor.java:17)
at java.base/java.nio.file.Files.walkFileTree(Unknown Source)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrateFileNames(Version7Migrator.java:119)
at org.cryptomator.cryptofs.migration.v7.Version7Migrator.migrate(Version7Migrator.java:101)
at org.cryptomator.cryptofs.migration.Migrators.migrate(Migrators.java:112)
at org.cryptomator.ui.migration.MigrationRunController.lambda$migrate$2(MigrationRunController.java:115)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:139)
Caused by: java.lang.IllegalArgumentException: com.google.common.io.BaseEncoding$DecodingException: Invalid input length 6
at com.google.common.io.BaseEncoding.decode(BaseEncoding.java:219)
at org.cryptomator.cryptofs.migration.v7.FilePathMigration.getDecodedCiphertext(FilePathMigration.java:221)
... 17 more
Caused by: com.google.common.io.BaseEncoding$DecodingException: Invalid input length 6
at com.google.common.io.BaseEncoding$StandardBaseEncoding.decodeTo(BaseEncoding.java:710)
at com.google.common.io.BaseEncoding.decodeChecked(BaseEncoding.java:233)
at com.google.common.io.BaseEncoding.decode(BaseEncoding.java:217)
... 18 more
I started reading about path length issues, but it seems I am even one step before “some files are lost” problems because migration process does not finish.
Any suggestions how to deal with it?
Additionally, I suppose that my oneDrive folder structure will be problematic because “root path” to \d is 77 chars (**C:\Users\Heiko\OneDrive - full path with domain\subfolder**d).
Thank you for your help!
Heiko
