Hello all,
I did install 1.5.0 but I am not able to create any vault. File system is ext4. I got some strange messages:
org.cryptomator.cryptofs.common.FileSystemCapabilityChecker$MissingCapabilityException: /home/mintuser/Cryptomator/myVault/c/aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa.c9r: Filesystem doesn't support LONG_FILENAMES
at org.cryptomator.cryptofs.common.FileSystemCapabilityChecker.assertLongFilenameSupport(FileSystemCapabilityChecker.java:99)
at org.cryptomator.cryptofs.common.FileSystemCapabilityChecker.assertAllCapabilities(FileSystemCapabilityChecker.java:57)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.initialize(CryptoFileSystemProvider.java:167)
at org.cryptomator.cryptofs.CryptoFileSystemProvider.initialize(CryptoFileSystemProvider.java:148)
at org.cryptomator.ui.addvaultwizard.CreateNewVaultPasswordController.initializeVault(CreateNewVaultPasswordController.java:165)
at org.cryptomator.ui.addvaultwizard.CreateNewVaultPasswordController.lambda$showSuccessScene$5(CreateNewVaultPasswordController.java:152)
at org.cryptomator.ui.common.Tasks.lambda$create$0(Tasks.java:33)
at org.cryptomator.ui.common.Tasks$TaskImpl.call(Tasks.java:139)
What went wrong?
Regards
CryptoTux
